91v6 im goin crazy help me! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2004, 02:45 AM   #1 (permalink)
View 91toyindiana's Photo Gallery
having problems wiht my truck.. once was driving around 60mph all the sudden it hesitated for few seconds then stopped drove normal for 2 weeks.. then wouldnt start.. towed it to mechanic he said it was distributor i had it replaced with used part..
picked it up it was out of time running bad spittn n sputtering drove it home turned it off and tried starting it later wouldnt start had to mess with timing to get it started. drove like crap went and had it timed with light .. engine ran smooter but still hesitated did run like it did 2 weeks previously..before first breakdown..well now its on time..next day wouldnt start in morning i messed with the distribtuor and turned it till it started and it worked..but now is out of time...i paid 35 dollars for nothing for the timing cause next day had to turn it to get it started..well brought it to the mechanic again..put it on light engine sounded smoother but then it started acting diff whenever u under the hood pull back on the throttle fast it would sound throaty and like it stall..cut off.. air sound...but it was in time so didnt wanna move it .. drove it home.. wouldnt start but i bet if i adjust the timing off it will start.. but its choking/air sound and hard to start is what my problem is..here in the past 3 weeks trial n error i put diff distributor in..also cap/plugs/wires/rotor/airfilter...fuel inj cleaner/gas treatment/engine restorrer im spenind too much money and goin nuts on this...dont make sense i get timing set then wont start in morningi i have to adjust the timing out of wack to start it...and i need help .. these mechanics dont know much bout toyotas..! its a v6 3.0 efi 91 ty if u can help ! when this is fixed im goin have to yell victory and let u all know .. im goin nuts!
91toyindiana is offline
Old 11-10-2004, 08:47 AM   #2 (permalink)
View dram's Photo Gallery
Basically same problem I'm having with my 1992 V6 forerunner . I posted problem yesterday and so far I've hear could be ignition coil , but haven't had chance to try coil . Good luck ! If you get your's going , please let me know and I will do the same for you .
dram is offline
Old 11-10-2004, 12:15 PM   #3 (permalink)
could this be
could this be timing guides? i heard thru the grapevine its possible its the timing guides broke? i had the belt looked at partialy it wasnt missing teeth but was getting to the point where it needs replaced
Old 11-10-2004, 02:16 PM   #4 (permalink)
reb
View reb's Photo Gallery
My first thought was that the timing belt must have jumped, upsetting the timing. Resetting the ignition timing would probably make it run again. I don't know how many times you could go through this routine before the mechanical timing would be too far off, though. My guess is that, since the truck is due for a new timing belt, that if you replace it, you will see the problem when it is apart.
reb is offline
Old 11-10-2004, 05:11 PM   #5 (permalink)
guess thast my best option is to change the belt whats normal price to pay to change the belt..and i was wondering i hear alot bout the guides.. do the belts have them also i hear alot of stuff bout that but only so far with the chains.. and also im having problems getting the fuel filter off.. the lines are rusty and dont wanna snap the fuel line..ty
Old 11-10-2004, 08:06 PM   #6 (permalink)
hey if your reading this leave a reply
Old 11-10-2004, 09:10 PM   #7 (permalink)
Give me somethin to break
View Greasygreg's Photo Gallery
it must suckto be you guys.if you do go crazy, maybe theyll put you in a rubber room with yoyota emblems emblazed in the walls, and then you can bounce off them all day,!sorry thats a lame reply,but you might be on the right track with the timing belt.I dont know about the 3.0, but i do know that on 22r's if the timing is more than a tooth off mecanically with the chain;you end up bending valves.I'd probably get the manual,changing the belt does require a puller for the crank pulley,so its a fairly complecated procedure,and good mecanics arent cheap.Toyota recommends timing belts at 60 thousand miles,but they'll go a LOT longer,how mant miles on your rig?
05' Tundra Doublecab 4x4.Gold & been Rolled
Greasygreg is offline
Old 11-10-2004, 09:19 PM   #8 (permalink)
236k miles.. heres one thing that could be the problem.. when it broke down it was only gettin spark from half the wires coming out of the cap..so i replaced the distributor with a USED one..replaced it and timed it.. but runs like crap then got worst where i gotta advance the timing to get it started..and hesitant could i bought a bad distributor? to cause it to be adjusted each day to start and run like crap once its timed..or coil my next purchase or belt replacement ...jalsdfjlkasdfjlkasf
Old 11-10-2004, 09:29 PM   #9 (permalink)
doesnt sound like an easy fix, but my thought is that you shouldnt have to change the timing to start it.i hope that the engine hasnt jumped timing on you.im the wrong end of the horse to ask, but id suggest putting the crank on the notch for the timing mark, and unscrewing the cap to make sure its pointing the right direction and go from there.if theres a napa store nearby, they'll check the coil for free.Good luck!
Old 11-10-2004, 09:49 PM   #10 (permalink)
if the rotor isnt facing the number one should i take the distributor out and move it till its facing number one
Old 11-10-2004, 10:21 PM   #11 (permalink)
reb
If it is running at all, I would expect the rotor to be pointing at #1 with the notch on the timing mark. It sounds like something is moving when you run it after setting the timing. The only thing I can think of is the belt slipping, but maybe there is something else? I helped a guy change the belt on another vehicle once and he didn't get it together right and something caused the belt to jump a notch. It didn't damage that engine, just caused it to run rough, with little power.
BTW, I think the cost of replacing the belt in the 3.0 V6 is around $150.
Good luck. Be sure to let us know what you find.
reb is offline
