'02 high idle at start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2004, 12:06 PM   #1 (permalink)
View milaevo's Photo Gallery
Hello all, I have my 02 tacoma which seems to idle very high when it is cold out, it idles at 2000 rpm sometimes, does any else have this problem? Mine does this only intermittant, I think it might possibly be a computer error. Any ideas?
Just another Toyota Owner
------------------------------------------2002 Taco 4wd
2-10 eclipse subs w/2000w amp
6-disc indash stereo
Line-X liner
1987 Supra
Brembo Rotors
MSD Coil & Wires
NGK Platinum Plugs
milaevo is offline
Old 11-14-2004, 02:04 PM   #2 (permalink)
View MrSkott's Photo Gallery
The computer manages idle during warm up and then should slowly drop idle once it is warm....my buddy has a 01 and it idles around 1800 then slowly drops. My 91, idles at 1500 while cold then drops to its customary 750-800 when warm. High idle allows the engine to warm up quicker, move oil into the upper reaches of the engine quicker, etc. Hope this helps.
1991 Toy Dlx 3VZE Ext Cab, 5 spd. 4" ProComp lift + Traction bars.
4.88 gears. K&N air. Centerforce clutch. 33x12.5 X-terrains on Weld Rims.
MrSkott is offline
Old 11-16-2004, 10:45 AM   #3 (permalink)
Yeah I know about high idles and warming the engine. just the almost 2000 rpm is really high compared to all the cars I've had. But if this is the normal setting for the tacoma now worries. Thanks
Line-X liner
1987 Supra
Brembo Rotors
MSD Coil & Wires
NGK Platinum Plugs
milaevo is offline
Old 11-16-2004, 10:58 PM   #4 (permalink)
I would run it by a service tech at your local toyota dealership....they will be able to answer that one in a jiffy.
Scott
MrSkott is offline
Old 11-17-2004, 10:52 AM   #5 (permalink)
snowboarder2359's Avatar
View snowboarder2359's Photo Gallery
it will only do that when you engine is cold. mine does it in the winter quite a bit too.
Brandon
~ 1992 Toyota Pickup 4x4 DLX 22-RE ~ 121,000 miles ~ Flowmaster 40 Series ~ 3" Lift ~ 33x12.5 On The Way ~
snowboarder2359 is offline
Old 11-17-2004, 01:23 PM   #6 (permalink)
View kuto's Photo Gallery
yea thats normal, but what will happen if i turn my idle speed lower than spec, i was told that id save gas.....what other things could happen if i go through with this?
kuto is offline
