TP sensor with no ohm reading? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-14-2004, 05:08 PM   #1 (permalink)
View scrowley111's Photo Gallery
I have a 86 4runner with the 22re EFI. When i check the TPS for the resistance in ohms it doesn't read anything at all. with the throttle in any position. Is it bad??
scrowley111 is offline
Old 11-14-2004, 07:46 PM   #2 (permalink)
View djhyatus's Photo Gallery
Sure is bad. You might also want to try testing the voltage as well just to make sure.
djhyatus is offline
Old 11-14-2004, 08:35 PM   #3 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
What pins are you checking across? Don't have my book with me but there are several pins with different reading at different throttle positions.
It's an expensive thing to replace and I don't want you wasting money.
texas12 is offline
Old 11-14-2004, 08:54 PM   #4 (permalink)
It measures infinity at every position. I have the instruction for testing it from toyotatech. When it is at no throttle it is infinate also. I am getting the code for it when i did the code scan. It doesn't run horrible but is definatly loosing power and the timing doesn't change when i plug in the short for the test connector.
what is the voltage test for the TPS?
Old 11-14-2004, 09:02 PM   #5 (permalink)
texas12's Avatar
The voltage test is done off another one of the connectors at the drivers fender where you can see the voltage step up as you more the throttle position. I your case, I don't think it would help. It sounds like yours is fried.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
