1994 Toyota pickup auto trans problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2004, 07:52 AM   #1 (permalink)
View dw1973's Photo Gallery
USA 1994 Toyota pickup auto trans problem
My 94 Toyota PU 4 cylinder automatic has a trans problem with shift points. It has 121K miles on it. It shifts into second around 20mph, third at 45-50mph, then 4th at 55mph. It does not slip and still has good acceleration and does not leak. I changed the fluid and it was dark red. The filter was changed also this past summer. What could be wrong and how much money to fix?
dw1973 is offline
Old 11-16-2004, 09:31 AM   #2 (permalink)
View Billy_The_kid29's Photo Gallery
try adjusting yr shift linkage
ottawa canada
Billy_The_kid29 is offline
Old 11-16-2004, 11:16 AM   #3 (permalink)
reb
View reb's Photo Gallery
How hard are you pushing it for those shift points? If you are flooring it, those numbers could be reasonable. If you are light on the throttle, they sound high.
reb is offline
Old 11-16-2004, 03:40 PM   #4 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
I believe that shift points are calculated off TPS position also.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
