22re are they notorious for cracked manifolds?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2004, 08:33 PM   #1 (permalink)
View scrowley111's Photo Gallery
I have a 86 4runner and i was wondering if a lot of the exhaust manifolds crack on that motor (22re)
scrowley111 is offline
Old 11-17-2004, 12:27 AM   #2 (permalink)
View 34YRSOFTOYOTAS's Photo Gallery
Yes, that is a common problem with the 22RE. I have had several crack on me over the years. Also you can't weld the cast iron manifold effectively. The head studs and nuts also tend to come loose and strip. If you remove and replace the manifold be sure to remove and install new stud screws with the proper hightemp locktite and torque specs. The old studs will have lost any elasticity and if overtorqued or overheated will strip out.
34YRSOFTOYOTAS is offline
Old 11-17-2004, 07:56 AM   #3 (permalink)
View Rycam's Photo Gallery
I say leave the studs in place if at all possible! Soak the fasteners with PB Blaster for as many days as possible. Do not drive the truck at this time to keep the penetrant from cooking off.
If you do strip one of those studs out, you are looking at a headache. Lots of shops cannot/will not helicoil the damaged aluminum threads with the cylinder head in the truck.
I do recommend new nuts from the dealer.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 06-22-2006, 01:43 PM   #4 (permalink)
View nationaldophin's Photo Gallery
exhaust manifold torque specs
Anybody have information on the tightening sequence and torque specs for the 1988 22RE?
nationaldophin is offline
Old 07-08-2006, 08:27 PM   #5 (permalink)
View fast68's Photo Gallery
thi is really a problme on these?
never heard of it
i dont think it will happen to my 88 22RE
first time ive heard such a thing
how many has it actually happened to
good luck
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline
Old 08-22-2006, 05:07 PM   #6 (permalink)
Banned
View ovrrdrive's Photo Gallery
No. This is not a common problem at all. I've never even heard it happening to anyone at all except for the above poster.
Follow torque specs much?
I'm guessing no.
ovrrdrive is offline
Old 08-23-2006, 02:28 PM   #7 (permalink)
Toyota Fixer
View Jesster1's Photo Gallery
Actually this is a common problem on the 22R-E. I have been working for Toyota Motor Corporation for about 7 years and this is a problem that existed since 1985 since the first Pick Up's and Celica's came out. It is a good idea to use the PB Blast or Toyota Penetrating Liquid available at any dealer. Torque is 37ft/lbs for the exhaust nuts. There are a couple of aftermarket vendors that carry a replacement unit but dont expect it to last as long as the OE one. Good Luck!
Jesster1 is offline
Old 08-23-2006, 09:48 PM   #8 (permalink)
DCM
One with the farce
View DCM's Photo Gallery
The only manifolds that I have seen crack on the R engines is the 4-into-1 type, but never on the 4-2-1 oem manifold. Have your manifold resurfaced to be sure it's flat before re&re-ing the gasket, etc..
DCM is offline
Old 09-26-2006, 03:03 AM   #9 (permalink)
zeb
View zeb's Photo Gallery
i still have the stock manifold on my 86 and i don't have any cracks nor does a buddy of mine and his is a 85 and we both have 22 re.
zeb is offline
