1990 4x4 3.0 V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-17-2004, 12:02 AM   #1 (permalink)
View eStine's Photo Gallery
Question 1990 4x4 3.0 V6
First time here. My grandson is having trouble with his pickup(which i may buy). The #1 cylinder has lower compression than the rest. It don't smoke, he was told that its not the rings. As you can tell by my question I'm not a mechanic,so any help would be great. Is this year model any good and what about the 3.0 V6?
Thanks.
Elzie
eStine is offline
Old 11-17-2004, 12:19 AM   #2 (permalink)
View 34YRSOFTOYOTAS's Photo Gallery
Check with a toyota dealership to see if the headgasket recall for the 3.0 Liter V6 engine applys to this vehicle. If it is not the headgasket it is probably a damaged valve or valve seat. I would not buy it until this is resolved or you know what it will cost. Also if the compression is within 10-20% of the other cylinders it may not be a big deal.
34YRSOFTOYOTAS is offline
Old 11-17-2004, 01:07 AM   #3 (permalink)
34YRSOFTOYOTAS, Thanks for the info. I will check it out. The pickup is in real good shape and I can get for $1500. He seems to think it is a bent valve.
Elzie
eStine is offline
Old 11-17-2004, 01:13 AM   #4 (permalink)
View MrSkott's Photo Gallery
Mileage may play a large factor, if it is high (mine being 220.000) then a simple valve adjustment may fix your problem. The 3.0 uses shims which are pretty difficult to try on your own, so would recommend taking that job to the shop. Discovery of a bent valve would show during the valve adjustment and could be replaced.
Scott
1991 Toy Dlx 3VZE Ext Cab, 5 spd. 4" ProComp lift + Traction bars.
4.88 gears. K&N air. Centerforce clutch. 33x12.5 X-terrains on Weld Rims.
MrSkott is offline
Old 11-17-2004, 01:40 AM   #5 (permalink)
Scott
Thanks for the reply. I will do some checking around on repair cost. Not sure of the mileage, will check on that too.
Elzie
eStine is offline
