1994 22RE 2wd auto - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2004, 10:08 AM   #1 (permalink)
View bobbi's Photo Gallery
1994 22RE 2wd auto
1994 2wd 22RE auto shortbox 161,000 , no electricity at the fuel pump , and no electrical pulse at the fuel injector. Squirting starting fluid in the air intake while cranking the motor starts the truck but it dies when you stop squirting the starting fluid. I used that information to determine that the engine was getting spark. I have power to the EFI relay and I have exchanged identical relays and continue to have no power at the fuel pump or fuel injectors.
bobbi is offline
Old 11-18-2004, 11:25 AM   #2 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Is the EFI relay the one under the hood?
There is an EFI fuse in the inside fuse box. There is also a circuit-opening relay mounted by the computer. If that relay goes, no fuel pump power.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
