The fuel pump does not turn ON with the ignition in ON position. When you crank your engine and your Mass Air Flow sensor detects air flow, that is when the fuel pump turns ON. There is a connector under the hood on drivers side fender (single wire connector) to short to ground that will manually turn ON fuel pump with ignition ON and bypass MAF.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
