#@*$# T-100 ignition lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2004, 12:54 PM   #1 (permalink)
View 200kT100's Photo Gallery
The ignition lock on my '93 T-100 gave up. The steering column will unlock, but the key will not advance to "ACC". The dealership (50 miles away) says that there is a release pin BUT the key must be advanced to "ACC" to expose it; my key will not advance that far. The dealership says the service manual doesn't address this problem. I have the new lock on order, but be damned if I can get a straight answer on removing the old one. Anybody ever deal with this or do I take a Sawzall to it???
200kT100 is offline
Old 11-22-2004, 05:28 PM   #2 (permalink)
reb
View reb's Photo Gallery
My inclination would be to take a drill to it. Let us know what works for you. Mine might be next.
reb
reb is offline
Old 11-27-2004, 09:57 AM   #3 (permalink)
Fix was easier than I thought
Since I was being run in circles, I went to techinfo.toyota.com for help. I spent $10 to access the site for one day and printed out every section and sub-section of the t100 repair manual I thought I could use. While I didn't find anything of real help regarding the ignition lock, I did find the exploded view of the dash/instrument panel. Following the diagram, I tore down the lower portion of the dash, below the instrument cluster (pretty easy, just take it slow. Lots of plastic fittings, easy to break). Once I had the lower dash removed, I could see the entire ignition lock and switch.
Now, everybody told me "you're gonna have to drill the lock to get it out"; I mean EVERYBODY said that. Having never drilled an ignition switch, I went to my local hardware store and talked to the owner (who is also a locksmith) about the process. He had an interesting observation: I could turn the key far enough to unlock the steering column, but not far enough to get to "ACC". He said "The problem doesn't sound like the tumblers in the lock, it sounds like a problem with the ignition SWITCH. He took a close look at the ignition key and noted that the key was worn down in several areas (no big surprise). His suggestion was to cut a new key ($2.15). His thinking was that excessive wear on the original key was causing a portion of the mechanism between the lock and the switch to fail (not operate properly) OR the SWITCH itself was bad. I took his advice (for $2.15, why not??). He cut a new key and, on the third try, the key rotated to the "ACC" position on the lock.
Now, the release pin the dealer described to me is located to the bottom right hand side of the cast switch housing (you'll have to look closely; the pin is recessed). The point is that, once the key was in the "ACC" position, depress
the release pin and the lock slides right out. Now, I was so friggin' happy as to the ease of the fix, I took the old lock back to the hardware store owner. He compared the old switch to the new one and noted that there is a small elongated pin just behind the face of the lock that moves up and down as the key is rotated. While the elongated pin on the old lock did move, the pin on the new lock moved upward considerably more than the old one. In addition the old lock had a bunch of play in it, another contributing factor.
As I prepared to install the new ignition lock, I noted that there is a small molded plastic switch INSIDE the cast switch housing, right at the mouth of the housing. When the lock is in place, and the key is turned, that elongated pin in the lock makes contact with the switch inside the switch housing. Now, I have no idea what that plastic switch does, but obviously it trips something in the switch that allows the key to rotate to "ACC".
So, Reb - If your ignition lock is hinky, try a new key. (Some lock lubricant is probably worth a try, too). Big thing is, if the lock just stops working, it may be excessive wear in the lock mechanism; you'll still need to replace the lock, BUT you may not have to drill the damn thing out. The other thing is that, even if you do replace the lock, it may not solve the overall problem. The ignition lock may be just fine; the problem could reside in the switch.
Incidentally, the replacement ignition lock was $80; keep in mind that you'll still need the OLD key to unlock the doors.
200kT100 is offline
Old 09-16-2005, 07:23 PM   #4 (permalink)
View fartyford's Photo Gallery
Thumbs up Thanks
Thank God for the internet, and thank God for 200kT100. I found the article about the ignition switch just in time, before I "torched" my Camry for the same problem. Getting the tumbler assembly was no problem, but how in the heck to remove the old one??
Then I read about the secret to removing the tumblers and my problem was solved!! My switch decided at random times not to let me put the key in, or if I did, I couldn't turn it. I found that if I tried over and over it would finally catch and work OK. Then, it decided at times not to let me get the key back out!!
Anyway, everything is great now. Thanks for being here!!
Fartyford (a long story)
fartyford is offline
