clatter in 22RE
Here is the on-going saga of my 22RE's clatter. For those of you who have not been privy to this soap opera, I had a timing chain cover wear thru on me, mixing oil and antifreeze in my oil pan. No sooner had I fixed this that I spun my #3 connecting rod bearing. I pulled my engine, cleaned up the damage and installed new connecting rod bearings, masin bearings, gaskets and seals. As the compression has always been good, I did not disturb my pistons and did not do rings. The head has been done 40,000 kms ago (about 25,000 miles). This is in my '88 4Runner, std trans, with 195,000 kms on the engine.
I currently have a clatter somewhere near #2 or #3 cylinder, sounds like to the passenger side of the block. The valves are reset at spec while the engine was hot. Oil pressure is at specs. I have rechecked the compression (still bang on the specs), drained the oil and filtered the oil to find shavings (a half dozen small particles, about what you would normally clean off your drain plug-so it is not a spun new bearing), refilled the oil with 10W30 and a quart of Lucas oil stabilizer. Upon warming up, the engine once again has the same rattle, which is upon slight decelleration when revving over about 2200RPM. If the rattle was in an oiled section of the engine I would asssume that the Lucas would change or muffle the noise. Same thing if it was piston slap or a noisy wrist pin.
My question is does anyone have any idea what this noise could be? Could it be a bad injector? Ideas?
D'mon
{very frustrated}
