Timing chain question..
Ok, I've been having some problems with my 22RE lately (no surprise :P), mainly that there is an excessive amount of smoke/vapour coming out of the exhaust.. Now I've been monitoring coolant and oil levels, and they are both steady so I know it's not either of them. My air filter is clean and new, and it looks like lots of air is getting to the engine. The problem is that I rebuilt the engine this summer after my head gasket went on me. I was talking to a friend who helped with the rebuild about this problem, and he got kinda squirrelly and embarassed. He said that when we tied the timing chain up and out of the way, his knot came loose and MIGHT have caused the chain to skip a cog. He didn't want to say anything then because of the amount of work it would be to fix. Is it possible that my chain is out by one link? Could this be causing my excess vapour/smoke? (Seems like the engine would be running lean with that much exhaust but would the chain being slightly off cause this?) And is there any concrete way to check for SURE if the chain is out slightly? Thanks in advance..
