knocking 22re - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-27-2004, 07:10 PM   #1 (permalink)
View scrowley111's Photo Gallery
knocking 22re
I have a 86 4runner 22re that just started to knock. I was in some deep mud in 4 LOW going back and forth trying to get out. Beating on it a little but not over revving the motor. After i finally got out it still sounded alright. I started it a couple days later and about a 2 hour wash and the motor makes a knocking noise from 2300rpms to 3900 rpms. It doesn't knock at idle and then goes away at about 3900rpms. The oil pressure is fine. Got the timming chain done about 2 days prior to mudding. If it was the rod bearing wouldn't the noise be constant with knock at idle also. sounds more it the top/mid engine. motor has 138k. any suggestions.
scrowley111 is offline
Old 11-27-2004, 10:03 PM   #2 (permalink)
Banned
subliminaltrips's Avatar
View subliminaltrips's Photo Gallery
could be a rod but maby something you did during wash messed up the timing , timing can cause an engine to knock just take a 12mm wrench and adjust on it a bit , move the distributor one way a few degrees and try the throttle and then if it doesnt help that way try the other , if not id say you might have somthing mechanical like a rod bearing or maby not as bad like a flywheel or something ? i dunno but a rod bearing doesnt always knock if its not completley spun but it will definatly scar a crank. does the vehicle crank over easily or run rough? im not the expert with the toyota's but alot of times engines will knock due to sensors and other things but for it to just start knocking like that after a littkle bit of romping sounds like alot of stress and it may very well be a rod bearing , but with rocking back and forth it could be the tranny or flywhee..
subliminaltrips is offline
Old 11-27-2004, 11:23 PM   #3 (permalink)
'73 FJ40
fj40Dave's Avatar
View fj40Dave's Photo Gallery
Wrist pin.
Doesn't make noise when your puting the pedal down, and doesn't make noise when you're completly off it.
Only when your just staying steady or close to coasting?
'73 FJ40 350/SM420 etc etc
'75 SR5
'95 & '96 Road King's
'99 4Runner
'04.5 Dodge 3500 DRW CTD
fj40Dave is offline
Old 11-28-2004, 05:23 AM   #4 (permalink)
View PINTECH's Photo Gallery
Sounds like a flat spot on a rocker.
PINTECH is offline
Old 11-28-2004, 08:25 AM   #5 (permalink)
View body's Photo Gallery
You may have a little piston slap that usually shows up when the engine is in a nutral rpm not accel or decel (kida like floating)
body is offline
Old 11-28-2004, 12:45 PM   #6 (permalink)
It is the loudest when it stays at steady rpm. what is the fix for piston slap??
Old 11-28-2004, 12:47 PM   #7 (permalink)
It does sound like it is more in the top end but not a lifter so a rocker sounds like a good idea. How can i check the rocker to see if that is the problem??
Old 11-28-2004, 12:49 PM   #8 (permalink)
Originally Posted by fj40Dave
Wrist pin.
To check for a problem in a certain cylinder i just pull the plug wires one at a time right. It makes the noise the loudest when it is at a steady rpm. 2000rpm to 3800rpm.
Old 11-28-2004, 05:42 PM   #9 (permalink)
scrowley111 You will have to pull the valve cover off and use a feeler guage and ck the clearance between the valve stem and the rocker, This is a wee bit of a time consumer but worth it. If the valve clearances are within limits. you are probably looking at a wrist pin or some piston slap only fix for that is to find the faulty component and change it. IE wrist pin change the piston+pin+rod or if you have piston slap you are looking at changing a piston and possably a bore job if it scored the cyl wall.. Lots of senario's here bro and alot of the fixes depend on the amount of damage that is there...My 22re has a long list of ticks and knocks but im not messing with it till its time to rebuild..
body is offline
Old 11-28-2004, 08:23 PM   #10 (permalink)
The way I check a rocker is pull the valve cover and put something over the timing sprocket to keep the oil from getting everywhere, and start the engine. Take hammer wood or rubber handle, hold it by the head and put the end of handle on each adjustment screw and push with a little pressure. Good rockers will be smooth. One with a flat spot you will have no trouble feeling it. Hope this help, and good luck.
Pintech
PINTECH is offline
Old 11-29-2004, 10:02 AM   #11 (permalink)
Will the motor last for a while with the knocking?? It seems to run with full power. Another thing is when i'm going up a hill (load) the knocking isn't really there at all.
Old 11-30-2004, 07:31 PM   #12 (permalink)
A rod bearing makes more noise at the oil pan than elsewhere, and a wrist pin more racket up on the water jacket. Hold RPMs at 2500, jerk the throttle open and let it snap closed. This will accentuate rod knock, whereas pin noise won't change very much.
Now's the time to starting shorting out cylinders. A bad pin will quiet down, but a rod knock will double its cadence.
Finally, you can pull the pan for a visual inspection. If the bearings are good, you know you've got a pin problem.
body is offline
Old 11-30-2004, 08:32 PM   #13 (permalink)
View toysarefun's Photo Gallery
Amazing.., what causes a rod bearing to go bad
This same thing is happening with my 22re but I did not notice the knock until 5000 miles after the timing chain/gear were replaced. I've driven it another 5000 with this noise. Why would the rod bearings go bad?
I can't exactly determine where mine makes the most noise but oil pan area seems to be where its loudest.
What causes a wristpin to go bad?
toysarefun is offline
Old 12-01-2004, 05:38 AM   #14 (permalink)
toysarefun normal wear, excessive rpm's, extreme loads put on the engine just like anything else pound on it and it will eventually break.
body is offline
