Originally Posted by justinvalencia
i have an 89 pickup ext cab 4x4 v6 with 180k, and i want to make a dune beast out of her. i am probably gonna get a 3.4 swap done and add an sts turbo system and push about 250 whp. now i want to keep it 4x4 and i want a minimal lift, ill cut out my fenders and put 33"s on, but i want my suspension front and rear to have some sort of long travel system so i can WOT on the woopdies* without losing control and bouncing allover the place...
are there any packages that sell all the basic components to a long travel 3-5 inch suspension lift?
also i dont mind cutting into my bed.... i just dont want to have to cut my whole bed out and only have the fenders...
Hi there, I hope you or anyone out there can help. I have 90 4x4 V6. The wire harness that run along side the passager fender is missing (it got cut) This part of the wire harness should be connect to O2 sensor, speed sensor and backup light sensor.
I need to know the colors that go to these sensor and also since I'm missing all PLUGs, the 02sensor have 4wire plug with black, black, blue and white on it, I will need to know how to match the wire from wire harness to these plug
Please help, I can be reach at 619-990-1700 if you can help
Thanks
