22re turbo rebuild? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2004, 11:22 PM   #1 (permalink)
View dirtbikeendo's Photo Gallery
22re turbo rebuild?
Are there any rebuilds for the 22re turbos that came stock on them? how hard would it be to adapt a naturally aspirated 22re to a stock 22re turbo setup? thanks for the help
dirtbikeendo is offline
Old 03-23-2006, 01:22 AM   #2 (permalink)
View jizneremie33's Photo Gallery
i think the 22ret block had different holes drilled than the 22re block because of the different oil needs for the turbo. also i think the head might be a little different There are turbo kits for the 22re though. i think i saw them at www.lcengineering.com
jizneremie33 is offline
Old 04-10-2006, 11:17 AM   #3 (permalink)
1986 22r-te custom t3/t4
rctoyota's Avatar
View rctoyota's Photo Gallery
22r-te
i have a 22r-te turbo motor in my truck i recently just adapted a t3/t4 hybrid on it......the diffrence in blocks from a 22re to a 22r-te is the the turbo block has a oil line feed and a return port machined in the block. the heads are diffrent too.............. turbo head has bigger combustion ports for lower compression, other then that they are the same.........you can use a 22re head on turbo block or viceversus.
rctoyota is offline
