Don't you all just love this time of year?
Check these 2 things:
1: The valve at the firewall to the heater core. Make sure when you move the Cold/hot selecter/slider to hot the valve opens.
2: The heater core air bypass door. There is a door in the HVAC box that blocks air from flowing over the heater core when the Cold/Hot selector is on cold if it stays closed then the air doesn't flow through it but bypasses it.
I've covered heater troubleshooting in other posts you might do a search on "climate control".
90 Lexus ES250 Auto, 90 Lexus ES250 Stick, 88 Camry LE AllTrac Stick, 88 Camry Wagon
^Like it? Get yours from XSPEED!
