2 broken timing chains in 300 miles? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2004, 11:18 AM   #1 (permalink)
View edgerice's Photo Gallery
Question 2 broken timing chains in 300 miles?
my 1988 tota truck has just had a new timing chain and all components about 200 miles ago. then it just died. result broken timing chain. replace and got 110 mooore miles and chain broke again. any suggestions
edgerice is offline
Old 12-07-2004, 01:09 PM   #2 (permalink)
View KAUAI KANE's Photo Gallery
who put it in? did they put it in proprly ? maybe they put it in to tight
Nobody dies a virgin... eventually life screws us all
KAUAI KANE is offline
Old 12-07-2004, 07:26 PM   #3 (permalink)
myself
my dad and myself put it in and i have replaced it 2 other times(normal wear) with no problems.ps my dad has been a mechaic for 35 tears so it should be right lol
edgerice is offline
Old 12-07-2004, 07:34 PM   #4 (permalink)
View Rycam's Photo Gallery
Just a theory: The lower area of the timing chain cover has been a topic of discussion here. From what I remember, it is possible to install a bolt that is too long...and it can touch the testioner. Use the search button.
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 12-07-2004, 07:44 PM   #5 (permalink)
Found it!
Timing chain noise...with new timing chain?
Rycam is offline
Old 12-08-2004, 09:24 PM   #6 (permalink)
View canadianbiz's Photo Gallery
2 broken chains & motor is not toast?
Maybe someone could enlighten me about timing chains. I have an 86 toyo PU with a 22R engine. I have been reading that if you have an "interference" engine, breaking the timing chain can destroy the motor. However if you have an "non-interference" engine, there is no damage. Reading edgerice post, toyo trucks must have a Non interference engine because he broke the chain twice. Is this correct? Eric
canadianbiz is offline
Old 12-09-2004, 09:31 AM   #7 (permalink)
Raising your kids.
bkirchner81's Avatar
View bkirchner81's Photo Gallery
Correct. Our motors are non-interference- meaning that if the timing chain is broken, the pistons will not have the reach to impact the valves, which would be bad...
I was actually driving with a destroyed chain for a little while!
bkirchner81 is offline
Old 12-09-2004, 10:17 AM   #8 (permalink)
Thanks for the info. The old Toyo truck I bought has 350,000 Km on it. The previous owners had it for 14 years and they told me they only did regular light maintenance on it ie: Oil changes etc. I am ordering up a Timing Chain set and installing it in a week or 2 when I have the help of my son. After reading about the damage that can be done on some vehicles when the chain breaks, I was really starting to get alittle afraid to even drive it until the chain/sprockets/guides etc were replaced.
Old 12-10-2004, 09:43 AM   #9 (permalink)
View kuto's Photo Gallery
toyota dependability !!!! is it better to get metal backed guides or regular plastic....my take on this is...wen the chain needs replacing the guide breaks so u kno to change it , with the metal baked guides they dont break instead i feel that your chain might break not knowing that it needs replacing,,,,,, which should i get
kuto is offline
Old 12-10-2004, 08:03 PM   #10 (permalink)
View Bill C.'s Photo Gallery
Yes, but how do you know when the guide is breaking? I'm putting in a steel chain guide next time...
Bill C. is offline
Old 12-10-2004, 10:16 PM   #11 (permalink)
View xsacta's Photo Gallery
I had about 139000 miles on my '86 22r when the left guide broke. It must've been squeezed between the chain and the front cover 'cause it blew a hole through the front cover casting. The valves also got bent. This all happened right after I'd started it up and was still parked. I'd heard plenty of chain slap under load the previous few weeks but was too busy too address it. I ended up installing a 20R double chain kit with steel guides. The kit included a modified front cover. At 290K m. the 20R chain showed no signs of wear. Unfortunately I blew a hose on the interstate doing 85 and didn't see the temp gauge pinned and the head warped along with some other horrors. Oh well
xsacta is offline
Old 12-11-2004, 08:33 PM   #12 (permalink)
Originally Posted by xsacta
I had about 139000 miles on my '86 22r when the left guide broke. It must've been squeezed between the chain and the front cover 'cause it blew a hole through the front cover casting. The valves also got bent. This all happened right after I'd started it up and was still parked. Oh well
How did the valves get bent??? I asked this question (interference or non interference engine) earlier in this post because the Original Poster said he broke the timing chain twice with no engine damage, I understand the Toyota engine is a "Non Interference" engine which means no damage when the chain breaks.
Old 12-12-2004, 04:09 PM   #13 (permalink)
truck has 180000 miles on it but i have had it since it was brand new and hate to part with it. there is no damage to valvesn or is there anyplace that a bolt can reach the tensioner. that is a 22 re i believe. mine is just a 22r. i am at a loss.
edgerice is offline
Old 12-17-2004, 12:10 AM   #14 (permalink)
View superjoe83's Photo Gallery
most Toyota engines are non-interference, the 22r-re are a interference engine and may bend valves
superjoe83 is offline
