86 Turbo'd 4x4, no fast idle at cold start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-08-2004, 10:35 AM   #1 (permalink)
View bvenvert's Photo Gallery
I have a 1986 Toyota SR5 Xtra Cab Turbo that doesn't seem to have a fast idle on cold startups. The vehicle starts every time but never seems to jump to a fast idle. It also struggles with restarts after warmup. Once the vehicle is driven and completely warm, if you shut the vehicle off and let it sit for a few minutes, when you start it up again it has a hard time finding it's rythm. Any suggestions? A local mechanic made the suggestion that I should have the valves adjusted so the vehicle will run better all around, but could the valves cause idling issues?
bvenvert is offline
Old 02-10-2005, 12:19 PM   #2 (permalink)
LordoftheDings
View koolcheez's Photo Gallery
Sounds like a temp switch
I also have an '86 toyota turbo X-cab and I have a similar problem. Mine starts fine cold, but once up to normal operating temp and I turn it off and come back 5 to 15 minutes later it won't start. The longer it sits (cooler it gets) the better the chances of getting it to start. The local mechanics have suggested everything from plugs to fuel filter, but a service bulletin one guy printed for me seemed to make a lot of sense. In a nutshell, it pointed to the no.2 temp switch and the cold start injector time switch. The temp switch is a fix for a 5 to 15 min. soak/hard start/rough idle. The time switch is a fix for I think a 1 to 2 hour soak/hard start.
I've ordered the no.2 temp switch because it sounds closest to my symptoms and years ago when my a/c wasn't working, a mechanic replaced that same switch because it wasn't telling the ECU to "idle up" when the a/c was turned on so the a/c compressor wouldn't work. I should mention this new temp switch is an update from toyota that is responsive at a lower engine temperature causing it to tell the ECU to pressure-up the fuel system at a lower temp. If you have A/c, there is mention in the bulletin that there's a wire you need to disconnect from the ECU plug if you use this updated temp. switch or the engine will stay idled up after it is warmed up with the a/c running. I don't claim to be a mechanic myself but this fix does makes sense. Also, I have recently replaced my cold start injector, temp. switch no.1, a sensor to the right of the CSI time switch on the front of our 22R-TE engines, ignition control module($400 down the drain just for this part, old one still good if your looking for one), plugs, coil, distributor pick-up, all within the past year. All at the advice of a local mechanic and still have the problem. I especially enjoy when it leaves me sit at the gas pump. When I replace this switch I'll let you know how it works but right now I'm tapped out from all these other attempted fixes.
koolcheez is offline
Old 02-10-2005, 02:01 PM   #3 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
I was having the same problems with my '86 4runner (no turbo). As far as the fast idle, it was the aux air control valve. It was located under the intake manifold and cost just over 200 bones from the dealer. Could not find one at any other parts store except NAPA and they wanted about the same price plus shipping.
For not starting when hot, i've heard of 2 problems. #1 is cranking and not starting. #2, which was/is my problem was not cranking. Lights would come ON but starter would not crank. Tried replacing starter, had battery checked, no help. Replaced both of the battery cables and it got less frequent. Checked voltage on starter soleniod when it was not working and was only gettng 7v? Finally just ran a wire from starter solenoid to a switch in the cab and back to the battery (+). When it will not start, I bypass all electronics and push the switch. I have not got standed since.
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
