Ok, I have 1989 4WD V6 Manual Toyota Truck with approximately 181, 3XX miles, bought it about a month and a half ago when it had about 179,7XX miles and everything seems to be working great on it. When I purchased the truck from the original owner he stated he used the 4WD occasionally each year, they would take it up to their cabin and need 4WD to get through the snow. I did a search on this topic and was not able to find all answers to my questions and wanted to see if you guys/girls can answer them or post a link to a thread that has the answers. I understand some info will be in the owner’s manual but would like to also get first hand knowledge from people as manual’s sometimes aren’t very descriptive. My questions:
1. The owner had his front hubs in the locked position and I have left them there ever since. Will I be causing problems to my truck if I drive in normal 2WD (2H) mode with the front hubs locked all the time? What problems would I be causing?
2. I want to test out the 4WD (which I should have done with the owner but forgot) to make sure it works but very nervous I might do something wrong or advance an already existing problem. What I understand is not to use 4H or 4L in dry pavement/cement/asphalt. Please correct the following if I mis-understood: 4H is for driving on wet, icy, or snow covered pavement/cement/asphalt and 4L is used for climbing/descending steep hills, off road driving and hard pulling in mud, sand, deep snow. My question is when I shift from 2H to 4H, I need to first lock my hubs (which they already are, but will unlock them if this is bad to drive with locked hubs all the time), when I shift it into 4H do I need to make sure the truck is not moving and the wheels are not spinning? Does this apply (stopping the forward motion of the truck before shifting) any time I shift between 2H, 4H, 4L gears? Also the clutch is not involved with any of this correct?
3. Is there a recommended speed that I stay under when I am in 4H or 4L?
4. Anything else I need to be aware of or cautious of when I first try 4WD?
5. I more than likely will not use 4WD very often, but how often each year should I engage 4WD to make sure it continues to work properly and for how long (miles/mins)? (i.e. once a month, once every 3 or 4 months, once every 6 months, once a year)
Thanks in advance for you help.
