Originally Posted by doinou
I just bought a 85 pu with 22r. The guy said it over heated. Well I looked at the oil and saw no water in it. I replaced the plugs,cap and rotor. It get's spark and turns over but won't start. I tried putting gas in the carb and no luck I also spray starting fueled in it as well. If it had a blow head gasket, would that cause it to not start? Also would it be better for me to find a used motor or just replace the broken parts. Also how hard is it to pull the head? I use to have a chevy luv that had a 1.8l iszue motor and replaced the head gasket on it all the time? Also how much would a good used motor cost. I only paid $200 for the truck and the body is in pretty good cond.
If its getting spark,fuel check the timming chain..bets thats your prob why it wont start
Pull #1 spark plug and bring motor around till your on #1 cylinder and see where the rotor is facing under the cap
Hope this helps you out
