Radio noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2004, 01:32 PM   #1 (permalink)
reb
View reb's Photo Gallery
Radio noise
As my '94 T100 has aged, the AM radio reception has deteriorated. Engine noise drowns it out when I am in an area with weak signals. New ignition wires did not help. I figure there are some filters in the electrical system. Anyone know where they might be hidden?
reb is offline
Old 12-13-2004, 01:48 PM   #2 (permalink)
I only eat vegatarians
2tacomas's Avatar
View 2tacomas's Photo Gallery
You may want to think about replacing your speakers (if they are still original stock equipment). I had a similiar problem in my 1988 Toyota P/U, I went ahead and installed a whole new sound system- it solved the problem, sounded a whole lot better (I put more powerful speakers in it), was fairly easy to do myself, and it didn't cost nearly as much as I thought it would. If you plan on keeping that truck for a while longer, I would highly recommend it. Also, make sure your antenna is tight- sometimes they can work themselves loose and cause poor reception.
2004 Toyota Tacoma (Xtra-Cab, 4wd, TRD Offroad, SR5, 3.4 V6, Auto...)
Flowmaster 50 Deltaflow Series
Deckplate Mod
Grey Wire Mod
More to come!!
2tacomas is offline
Old 12-13-2004, 02:34 PM   #3 (permalink)
reb
Thanks, 2tacomas.
I will check the antenna. Since FM radio works satisfactorily, I am sure the speakers are not the cause of the noise. I will consider replacing them when the AM radio works correctly.
reb is offline
Old 12-14-2004, 02:17 PM   #4 (permalink)
View Billy_The_kid29's Photo Gallery
do you get engine noise on fm as well? if so you have a bad ground
ottawa canada
Billy_The_kid29 is offline
Old 12-14-2004, 06:14 PM   #5 (permalink)
View GregoryM's Photo Gallery
USA
Can you be more specific re. "engine noise"? Usually RFI (radio frequency interference) takes one of two forms. A high pitched whine is caused by the alternator/charging system. A rhythmic ticking is usually from the igniton system. Depending on the source you can track down the cause. A capacitor will usually quiet a noisy alternator. An electrical choke on the power lead to the radio can also help. An electronics store can help you select a proper capacity and show you where to connect it. If the igniton is the source, you can check the usual components: plug wires, dist. cap, rotor, resistor plugs, etc. Sometimes you can shield the antenna lead with aluminum foil and that has helped me in the past. You don't mention the condition of your antenna but, I will assume it is in good condition. Hope this helps. Good luck.
GregoryM is offline
Old 12-14-2004, 08:46 PM   #6 (permalink)
reb
Thanx for the suggestions.
I haven't figured out whether it is alternator or ignition caused. It isn't a whine and it isn't a rhythmic ticking. I suspect the alternator circuit, but I was hoping to locate the factory filters and check them out before digging deeper. Its possible that the antenna connections are corroded, too. The cable looks ok; so I expect the shielding to be ok. At times like this I curse the crowded wiring behind the dash. It is a b*@$# to work on.
reb is offline
Old 12-15-2004, 11:57 AM   #7 (permalink)
The factory uses capacitors in the charging circuit. You should be able to locate them with a schematic diagram. If the antenna is in poor condition, electrically, it sure could be your problem.
GregoryM is offline
Old 12-15-2004, 09:03 PM   #8 (permalink)
reb
I have the factory manual, with the schematics. The schematic does not give the physical location of the filter cap. I didn't see it the first time I looked for it. I guess I'm too lazy. I'll just have to break down and search more carefully. It should be close to the igniter &/or the ignition coil.
reb is offline
Old 12-16-2004, 01:26 PM   #9 (permalink)
Actually the factory wiring diagram DOES show where to look. It breaks down your vehicle into a grid. You must look within the designated "square" but it at least gives you a starting point.
GregoryM is offline
Old 12-17-2004, 01:13 PM   #10 (permalink)
reb
I spent my career working with electronic schematics in the avionics industry, but the automotive industry does things differently. I will have to study the manual to figure it out. So far the only reference I can find to component location points to areas in the schematic diagram to find things.
reb is offline
Old 01-22-2005, 08:34 PM   #11 (permalink)
View walterycrigler's Photo Gallery
I have the rythmic ticking problem in my 98 Camry LE. Has rear window integrated antennae -works fine. Ticking also occurs when (factory) cd is playing. How is this a signal bleeding into antennae problem? I dont understand - but would love to fix it. It seems to be getting worse.
walterycrigler is offline
Old 01-22-2005, 08:50 PM   #12 (permalink)
reb
If the ticking occurs with a CD player the antenna is out of the picture. It sounds to me like you have what we in the electronics business call "conducted interference." The noise is probably coming into your amplifier via the power line. There might also be a way for radiated noise to be carried into the amplifier, too. What are the characteristics of the noise? How fast is the ticking? Does it increase with engine speed? If the noise is getting worse, I would guess that the circuitry (possibly in your radio/cd player) that filters out the noise is degrading with age. I figure that is what has happened with my truck.
reb is offline
Old 01-22-2005, 09:05 PM   #13 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
You might wanna check your grounds.
http://www.xclusive.bz
dna59 is offline
