Check Engine Light AGAIN....HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-16-2004, 04:39 AM   #1 (permalink)
View jmelong's Photo Gallery
My 2001 Tundra Check Engine light came on and Toyota replaced the O2 Sensor last February. I later found out that there is a problem with the O2 sensors, and Toyota reimbursed me for the repair. Now the Check Engine light is on AGAIN. Is there any way to check and read the codes without taking the truck to Toyota? How about resetting the light? Any ideas?????
jmelong is offline
Old 12-16-2004, 05:46 AM   #2 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Auto-Zone (and others) can read the code.
- battery terminal disconnect for 30 seconds will reset code.
CraigW is offline
Old 12-17-2004, 09:37 PM   #3 (permalink)
View charlie's Photo Gallery
i bought a ScanGage $99 plugs into the diagnostics it reads teh error codes and will reset them also has gage information .. look it up on internet
charlie is offline
Old 12-17-2004, 09:45 PM   #4 (permalink)
View 91toyindiana's Photo Gallery
check engine lght
hey on my 91 toyota its gotta self diagnostics on itand dont cost anything... first u might wanna reset it by under the hood theres a fusebox take the ecu efi fuse out for like 1 minute or so to reset it then you gotta get a wire or paperclip and jump to terminals ...then the check engine will flash a code...to find out wich thing u jump on your year and the flash codes...check on the internet or haynes book..theres guy named sidney on here that has alot of information on that kinda stuff ...he seems real smart on all that
91toyindiana is offline
Old 12-17-2004, 09:49 PM   #5 (permalink)
View virtualkuz's Photo Gallery
Not going to work on an 01 Tundra. That trick only works on OBD-I cars. 1996 and later model years are OBD-II. There is no paper clip trick for these. You can take the truck to autozone like a previous post said. They are usually pretty nice there and they will pull the codes for free. If the scan tool just pulls a code they can look up in the computer what it means.
2005 Corolla XRS Silver Streak Mica
2005 Kawasaki Z750S Candy Plasma Blue
1993 Kawasaki EX500a Luminous Polaris Blue
virtualkuz is offline
Old 12-19-2004, 07:33 AM   #6 (permalink)
Thanks everyone for the replies and advice. I reset the lite, but it came back on after five miles of driving. I took the Tundra to Toyota, and believe it or not, the same O2 sensor has failed again. Toyota says there is such a high failure rate on these sensors that getting replacement parts is taking 4-5 weeks. On the bright side, at least the truck runs ok for now, and they are replacing it FREEEEEEEEEEEE.
jmelong is offline
