1980 truck coolant drain problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2004, 05:29 PM   #1 (permalink)
View reeljustice's Photo Gallery
We have our first real look at winter facing us in GA. I went to drain my coolant system this afternoon and there was only a dribble out of the drain plug. I wound up removing the bottom hose so I could put the antifreeze in.
The water that was in the radiator was the color or north Georgia red clay. Should I run some of a flush solution through the radiator? Other recommendations?
Thanks,
Joel
Don't miss the forest for the trees.
reeljustice is offline
Old 12-19-2004, 07:14 PM   #2 (permalink)
View 76toyota's Photo Gallery
I would fush the radiator out. Did you try to blow the drain out with compressed air, or stick something in the hole? If the rad is 14 years old, it really needs flushing real good.
76toyota is offline
Old 12-19-2004, 08:07 PM   #3 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
I'd recommend running Prestone flush thru the system. Run your heater(s) for the 5 or 10 minutes to clean theme out also. Then flush with clean water. I used Prestone, it gotrid ofthe oil contamination I got from my timing cover (and there was a LOT!!!). Put in a 60-40 mix, don't worry ever again.... at least for two years anyway.
D'mon
Heaven doesn't want me and Hell is afraid that I'll take over!
D'mon is offline
Old 12-19-2004, 08:24 PM   #4 (permalink)
Thanks fellas. I did not try sticking anything in the drain as the "plug" did not come completely out.
I will try the Prestone flush next weekend.
