I am not the biggest fan of wheel spacers, I have seen them come off on the trail (well a stud fell out and caused the brakes to seize).
Was a royal PITA.
They are a good quick fix to adjust track and fix things like frame rubbing with larger tires.
Not sure what type of wheeling ya do, but a 10" wheel will also help spread your track.
makes the tires real fat, but also come off the bead quicker below 12 psi.
Will probably want to keep it above 15 psi just to be safe.
I wuld not be affraid to use aluminum, Wheel studs will eat through mild steel too.
if you do use aluminum, coat the mounting surfaces with anitsieze. Will help prevent the aluminum from welding/sticking like a mother to everything else.
