4x4 not engaging - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2004, 10:57 PM   #1 (permalink)
View Mammouth's Photo Gallery
USA 4x4 Not Engaging
my 94 sr5 4x4 (v-6) will not shift into four wheel drive. other than checking for the obvious (fuse) what else could be wrong. the shift lever moves alright but no 4x4 lite on dash and 4x4 does not engage.
Mammouth is offline
Old 12-23-2004, 01:18 PM   #2 (permalink)
View 4runner95's Photo Gallery
Mine is having the exact same problem. Mine is engaged mechanically with a lever. So I got underneath and the lever does work fine. However when I put it into 4WD the front drive shaft does turn, in 2WD it does not. So I knowt he transfer case is working. What I am unsure about is the automatic engaging hubs. I think they are not working properly. If that helps I am glad, but you should check the linkage on the lever, then suspect something else.
Good luck
Craig
4runner95 is offline
Old 12-24-2004, 06:58 PM   #3 (permalink)
View Big Blue Truck's Photo Gallery
Transfercase switch is common on the side of the case
Big Blue Truck is offline
Old 12-26-2004, 07:23 PM   #4 (permalink)
Check this thread out. We have been discussing the problem.
http://www.toyotanation.com/forum/t60255.html
Craig
Old 12-30-2004, 05:52 PM   #5 (permalink)
Mammouth,
Did you get the 4WD working yet? I just fixed mine, and it was a vacuum leak, not necessarily connected to the ADD system. I checked all the components and found they all were in working order. If you haven't already, check all the vacuum hoses.
Craig
