Need to change front disc brake shims & springs? - Toyota Nation Forum : Toyota Car and Truck Forums
View Poll Results: Do you always replace the shims & springs?
I ALWAYS replace these when I change the pads 0 0%
I replace shims & springs only when they are worn 1 33.33%
I NEVER replace these when I change the pads 2 66.67%
What shims & springs? 0 0%
Voters: 3. You may not vote on this poll
Old 12-24-2004, 01:59 AM   #1 (permalink)
View MartinWolf's Photo Gallery
Question Need to change front disc brake shims & springs?
1995 T100 4WD SR5.
I am changing the front brake pads. Should I replace the anti-squeal shims and the springs? I had thought that the shims and springs should indeed be changed with the pads, but none of the local Toyota dealers stock the "Shim Kit" nor the "Fitting Kit" which leads me to believe that their Service departments don't regularly change these.
Whaddya think?
MartinWolf is offline
Old 12-24-2004, 10:17 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
re use the old ones, i have a 96 cam still with the stock ones aslong as they dont break they should be fine
^ and leaving it that way!
chronoti is offline
