Advice on used truck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2004, 12:03 AM   #1 (permalink)
View ExcellentRed's Photo Gallery
Hey guys,
I am currently am owner of a 93 F150 with about 155k miles. While I love driving around that big machine and getting 11 mpg with a 5.8 liter V8, I am getting sick of paying for gas and since I am just a poor college student I need something more practical and also extremely reliable.
My neighbor owned a late 80's toyota pickup that he put nearly 300k miles on with little mechanical problems. Toyota makes reliable trucks as far as i know.
So here's the deal...
I am interested in getting an early 90's toyota pickup. Here's what I would really like -
$5000 price
4wd
extended cab, short bed
20+ mpg city. Is this only possible with a 4 cylinder?
AC
What pickup would you recommend? Is there a certain year I should avoid? What engines are available, and what kind of mileage/performance can I expect from them?
Thanks alot for your help
ExcellentRed is offline
Old 12-27-2004, 09:57 AM   #2 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
early 90's toyota go for 1000 up to probably 5000. For me personally to buy an early (90-95) truck, itd have to look really good with somewhat low miles for tops of $5,000. Mines a 92 and in decent condition, 164,000 miles, 22-RE (which is the toyota 4cyl EFI) 5spd for $1,500. They are darn good trucks if they are taken care of. the extended cabs are popular for that time, and shouldnt be hard to find. I see more of them around here than regular cabs. Im not sure of the gas mileage, as i havnt ever checked mine. But should be around 20, or a little less. It depends on how you drive it. My 92 has good a/c and heat. works well. ive heard of these yrs trucks going to 250,000 + miles easially.
hope that helps
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
Old 12-27-2004, 12:41 PM   #3 (permalink)
reb
View reb's Photo Gallery
You probably won't get 20 mpg with 4WD. You will also sacrifice some of the reliabillity (more moving parts yields a higher failure rate). I was in your shoes a few (?) years ago and remember the budget problems. If I were there now, I'd opt for a clean 4 cyl 2WD (stick shift) and buy the 4WD after graduation. I'd also recommend the extended cab. The standard cab is cramped.
reb is offline
Old 12-27-2004, 03:11 PM   #4 (permalink)
Alright, thanks for the help guys. I think you are right about the 2wd, I have gone 3 years without it so I don't need it now heh heh. But I will definitely need the extended cab - I'm a little over 6'3". Speaking of which, will i be fairly comfortable in that size truck at my height?
And with the 2.4L, how much pickup will it have? I am used to a V8, though it is a little arthritic. Does it still scoot since it is a small truck?
Old 12-27-2004, 10:15 PM   #5 (permalink)
reb
It won't be a drag racer, but quite adequate. I was a believer in Detroit V8s until I got my first import 4-banger. I haven't wanted to go back.
I am 6'2" and found my '85 xtra cab quite comfortable. I believe the later trucks are a bit bigger.
Try one out; make up your own mind.
reb is offline
Old 12-28-2004, 12:04 AM   #6 (permalink)
I was reading that the '96's are alot nicer than the 95's. Power Steering, etc. Is this the case?
