Well.., the clunking noise is still your steering stops I say. Greese them and at least that noise will go away, and you can focus on the next. It is a very simple fix, get some greese and just do it. CV joints make a clicking noise typically. If the boots are broke open usually thats a sign that they could be going bad. Also.., if your hubs are not locked in, or your not in 4 wheel drive the CV joints are not even turning... You can jack the truck up, and inspect your wheel bearings, brakes, etc. which could be making a noise. The brakes are known for making clicking noise which is only a loose caliper, and the part to fix that is only a couple of dollars.
