timeing chain - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 08:18 PM   #1 (permalink)
View doinou's Photo Gallery
timeing chain
How do release the tension so you can put the spocket and chain back on? I had to replace the head on it.
doinou is offline
Old 12-28-2004, 08:41 PM   #2 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
If you look down the left side of the chain, there is a tensioner that is spring loaded. Maybe a long screwdriver? It is a bit** to do even with the timing cover off....
More knowledgable people will answer your question I'm sure.
D'mon
Heaven doesn't want me and Hell is afraid that I'll take over!
D'mon is offline
Old 12-28-2004, 09:09 PM   #3 (permalink)
View 924runner's Photo Gallery
you will have to push it back with something like D'mon said,make sure you turn it over after and the timing marks are ok.
what i do is i have a piece of wood on a wire and i wedge it between the tensioner and the guide(place it between the chain)and just drop the chain down
1992 4 runner 22r-e,cam,lift,35 inch tires,arb rear
http://bc4x4.com/album/steve-micaelo.jpg
924runner is offline
Old 12-28-2004, 09:17 PM   #4 (permalink)
so I need to push it towards the left side of the block.. Hopefully I can get this all back together and running toworrow as well
doinou is offline
Old 12-29-2004, 02:38 PM   #5 (permalink)
Will I have to keep pressure on it while I try to bolt the spocket on? Also , it's say that the notch on the cam needs to be in the 12o'clock postion? How can I turn the cam over to line it up while the chain is off of it?
doinou is offline
Old 12-29-2004, 08:36 PM   #6 (permalink)
you will have to bolt the gear on and turn it over then remove it the install the chain
