Ok the 89 Toyota Truck I purchased two months ago and just realized that the fan, for the vents of the cabin within the truck, is not working correctly. The truck doesn’t have A/C but I am looking to get one installed in the next month or two and wanted to see if I could resolve the fan issue before hand. The fan has four settings, Lo, then a dot for the next level which I will call 2, then another dot for the next level which I will call 3, and finally Hi. The problem is there is no air coming from the vents when I shift it to Lo or 2, but when I shift to 3 or Hi then it works properly. Going from Off to Lo I can hear a click, I’m assuming this is to kick the fan on. Anybody have ideas on what could be wrong? Or what things I can check to maybe determine what the problem is? Also if someone can here can give suggestions on what could be wrong, can you also give how easy/hard it is to fix and a general idea of how much it could cost to have someone repair if it is something I cannot do myself. Thanks in advance for your info and help.
