Tacoma exhuast manifold cracks
Hi, I have a 1996 tacoma 2.7 L with 120k miles on it, its had the oil changed every 5 k miles or more. I noticed engine noise when the motor first starts, I removed the heat shield in front of the manifold and noticed several cracks. The Engine is only 1/2 through is life cycle. From looking at other reports online, I see this is a common problem. I'm considering a new '05 tacoma, but with the problems I've had with my '96, I wonder is toyota can make a reliable product? Mt truck is vodoo to work on. Its obvious they designed things in a way to increase mechanics shop time. I've always been able to fix my own cars. I decided to adjust the valves, after 1 hour of working on it and removing all the hoses and crap, I was able to get the valve cover off, them come to find out you need a special tool and shims to adjust the lash, I mesured all my clearances and have some intakes that are running at .006 clearance, the exhaust are all at least .010". I called a local mechanic and he wants $350 to do the job, he was very honest and told me when he worked at the toyota dealership in the past, they only changed 1 shim for every 1000 they measured, he said if its not missing and it runs ok, don't worry about it, he said with the # of miles on your car, the lash will not change more then .002" in the next 50k miles. So I think the next thing for me to do is to get a new manifold even though I think its a toyota defect.
