Helping friend with engine install. Need some info. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-05-2005, 11:26 AM   #1 (permalink)
View lafave's Photo Gallery
I have offered my help with a buddy's '89 Toyota 4X4 engine install. I have experience installing 20R / 22R / and 18RG motors in my old '72 and '76 Celica's. He will be buying a used long block already assembled from a local parts dismantler with a warranty. What are some head's up things I should know going into this and where can I find good write ups / literature to make this go quick and easy.
Thanks for reading and any help.
lafave
lafave is offline
Old 01-05-2005, 04:29 PM   #2 (permalink)
View alfaspyder2's Photo Gallery
i just installed a 22r in an '86, with the help of one other person. If you have basic knowledge of installing engines, its pretty straight forward. One thing to keep in mind is to not tighten up the 'stiffening brackets' (those that connect to the lower portion of the bell housing to the rear of the block) until you get the bolts that connect those to the bell housing in place. Other then that its pretty straight forward, just make sure you've got a good chain hoist and have got the clutch plate properly aligned with an alignment tool.
good luck,
chris
alfaspyder2 is offline
Old 01-06-2005, 10:02 AM   #3 (permalink)
ttt
lafave is offline
