High Elevation and Winterization help? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2005, 01:12 PM   #1 (permalink)
View SpeshalK_82's Photo Gallery
Next October, I will be attending Wyotech in Laramie, Wyoming. I currently live and drive around the sea level elevation and will be moving to around 7,200 feet. How will this affect my 22R and what can I do with my weber 32/36 to help. Also, what are some of the better things to do as far as winterization is concerned where the temps get down to an average of 8 degrees in the winter ?? Any suggestions and help are greatly appreciated.
- Speshal K
SpeshalK_82 is offline
Old 01-07-2005, 01:25 PM   #2 (permalink)
reb
View reb's Photo Gallery
Use low viscosity oil--10W30 or 10W40 will be ok. A 50-50 mixture of antifreeze will be adequate. If you have a windshield washer, it will require antifreeze (not engine antifreeze), too. Re-jetting the carburetor might be good, tho I am not familiar with yours. The computer control on the later models compensates for altitude. Make sure your heater and defroster work. Take care in driving on the icy winter roads.
Good luck. That is some beautiful country. I used to live just south of there. We Coloradans could always tell when we crossed the state line because of the strong cross winds there. It is said that the locals there use logging chains hanging from the trees as wind gauges.
reb is offline
Old 01-07-2005, 05:53 PM   #3 (permalink)
View GregoryM's Photo Gallery
Although not strictly necessary, a 120 volt heater that pre-warms the coolant, sure is nice. They are relatively inexpensive, easy to install, and make things nice and toasty on those co-o-o-ld mornings. Good luck at Wyotech.
GregoryM is offline
Old 01-07-2005, 07:59 PM   #4 (permalink)
View Rycam's Photo Gallery
Rejetting may be "automatic"? Carbs measure air volume...not density...so the higher you go, the richer the mixture will be. This may help in winter. I lived near sea level, now my carbed 1984 lives at 3500'-4200' feet. Does Weber have a database?
Some people use stick-on-the-pan oil heaters to keep the oil warm. You can get an advantage if you can park your truck in a garage as you will notice a higher overnight temp if it is stored indoors. This keeps your coolant and battery warmer too, as the hot engine will heat the garage to some degree, and minimize heat-loss to the wind. Also, if this is your daily driver, a garaged truck is the sh*t...as long as you can get the garage door open. Frozen shut door handles, and iced windshields suck when your need to get to work on time!
Congrats on the move!
1984 4x4 Xcab...and...Stock 1990 Camry Sedan. 3sfe. A/T. A/C. P/S.P/B. Work car...I install TOYOTA PARTS 90% of the time, even when it hurt$.
Rycam is offline
Old 01-07-2005, 08:05 PM   #5 (permalink)
I have heard a steel post with a heavy steel chain is called an "Idaho weather vane"!
Rycam is offline
Old 01-13-2005, 12:01 AM   #6 (permalink)
Thanks for your help guys and thanks for the luck at Wyotech.
- Speshal K
