22re skips at around 2800rpm. Any suggestions??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2005, 09:40 AM   #1 (permalink)
View scrowley111's Photo Gallery
My 86 4runner with a 22re motor skips if it is at idle at around 2800 rpms if it is held right there. Also when i am driving trying to save gas the truck will skip if drivin at low rpm steadily. It throughs a code #7. (which is tps. tps wiring, or computer). I replaced the tps which had code #11 (tps) and know it picked up this skip with code #7. Anyone have this problem??? Please give any suggestions
scrowley111 is offline
Old 01-16-2005, 03:31 PM   #2 (permalink)
View PINTECH's Photo Gallery
Sounds like a stuck EGR valve. take the vacuum line off of the egr valve, plug it and check it at the rpms.
PINTECH is offline
Old 01-16-2005, 09:05 PM   #3 (permalink)
Banned
subliminaltrips's Avatar
View subliminaltrips's Photo Gallery
i had a problem wit a timing chain that after replacng it it did not skip anymore.
subliminaltrips is offline
Old 01-16-2005, 10:14 PM   #4 (permalink)
View OEMonkey's Photo Gallery
Did you adjust the new TPS when you installed it? It's a potentiometer, and if it has slots(which I think the RE has) it needs to be adjusted so it'll signal the correct voltage fr different throttle positions.
OEMonkey is offline
