Truck doesn't roll very well.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2005, 10:23 PM   #1 (permalink)
View Dobber1's Photo Gallery
Question Truck doesn't roll very well....
I have a 2000 Tacoma 4WD with 35K miles on it. It doesn't seem to roll down the road very well. The front wheels act as if the brakes are on. I have an '82 2WD that goes better in the snow than this truck does in 2 wheel because there seems to be such resistance coming from the front end. Is it this tight for a reason or is there something one can do to loosen it up. It's like something has been tightened too tight. Never had any work done to the front end....yet. Any help or suggestions will be greatly appreciated.
Thanks,
Marty
Dobber1 is offline
Old 01-10-2005, 11:29 PM   #2 (permalink)
tacojet's Avatar
View tacojet's Photo Gallery
It sounds like it needs to be aligned.
You may have too much positive caster. That would be my guess short of another mechanical steering problem.
I would get the front end off the ground first and see if you still have any binding.
tacojet is offline
Old 01-11-2005, 07:17 AM   #3 (permalink)
View PokerPlayer's Photo Gallery
Noticing any kind of weird tire wear? Outer edges worn down? Inner? Cupping?
PokerPlayer is offline
Old 01-18-2005, 04:22 PM   #4 (permalink)
View krazy530's Photo Gallery
Mine feels that way when I put it in 4wheel drive,Make sure you dont have it in 4whell drive,As far as them telling you a front end alignment,Not true if you had to much caster or camber your truck would do one of the following things,Pull to one side,squeal around conners. Not put a drag on it like you say,,,
krazy530 is offline
Old 01-18-2005, 05:11 PM   #5 (permalink)
Darren's Avatar
View Darren's Photo Gallery
You don't have manual hubs, therefore your axle shafts are always turning, and likely the reason for the difference. Not to mention it's a totally different truck altogether.
2002 4Runner Sport
285/75/16 MT/R's | Sway-A-Way & Old Man Emu suspension lift | TJM T15 front bumper | Rock Ware rear bumper | Slee sliders | Dual ARB's | 4.88 gears | Mickey Thompson Classic II's
Darren is offline
