Originally Posted by PatchworkYota
I'm planning to replace my clutch and flywheel this weekend (at 182k miles). The Haynes manual says to drain the tranny, but the factory service manual says not to. Anyone here do it without draining the tranny?
Also, last time I drained and refilled the transmission oil, I used 75w90 gear oil per the haynes manual, but it seems awful thick when cold. Anyone running lighter oil in there tranny.
Just hoping someone with experience can pass along some wisdom to save me some time/$.
I did it without draining the tranny (or transfer case)....just make sure you keep it level on the way out. I got it tipped a little and some oil came out the top where the shifters go, but it was no big deal. Just check and refill the oil once you get it back in.
After you get the driveline(s) off, and the tranny crossmember out, you can tilt down the tranny w/ the engine to reach the 2 top bell housing bolts. Those seemed the hardest to get...but with a couple long extensions, you can sit back at the end of the tranny and reach right up and get them (same way to put them back in). Just don't tilt the engine too far, as I did. My already rusting exhaust cracked right at the manifold....so now i have brand new exhaust
Also, take a look at your rear main seal while you have it apart. Mine looked good and wasn't leaking, but if yours is, nows the best time to change it. Changing the rear main seal doesn't require you to drop the pan, so its just a matter of popping the old out and tapping the new one in.
Have fun
