pickup fuel gauge - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 12:59 AM   #1 (permalink)
View HighRaven's Photo Gallery
Question pickup fuel gauge
have an 89 pickup . but the gas gauge doesnt seem to work. I've checked the fuse box and made sure it actually had gas in it . any suggestions for things to check would be great.
HighRaven is offline
Old 01-22-2005, 06:25 AM   #2 (permalink)
TN's SRT-4
MenaceSQL's Avatar
View MenaceSQL's Photo Gallery
It could be the sending unit. My sending unit crapped out once in my '89 truck.
MenaceSQL is offline
Old 01-22-2005, 10:37 PM   #3 (permalink)
is there any way to test the sending unit
Old 01-22-2005, 10:50 PM   #4 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
sure, pop it out of the tank and hook the wires to it, now turn the key on and raise and lower the float and watch the gage
fredk is offline
Old 01-23-2005, 11:18 AM   #5 (permalink)
View PatchworkYota's Photo Gallery
I'm not sure what the correct range is, but the sending unit is basically a float at the end of a wire attached to a potentiometer. It's located further back on the gas tank than the fuel pump housing. There should be resistance across the leads coming from it. (or between the wire and ground) If it is a dead short, or shows no connection (more likely), the sender is your problem. I've never had mine out, but I used to work for a fuel sender manufacturer. You may be able to service it yourself when you remove it. If it's accessible, you may ony need to clean the contacts that the float arm swings past. The floats sometimes develop cracks and become filled with gas, therefore not floating anymore. If you do remove it, soak down the bolts ahead of time with some pb blaster or wd40. I had a bolt break on me when replacing my fuel pump.
PatchworkYota is offline
