I have a question while you guys are on this subject. With 160,000 miles on my 22RE, I was checking my timing chain, and while I was at it, I figured I would adjust the valves because I knew they had never been done before (at least I haven't done them and I suspect the previous owner didn't).
Before I adjusted them, I couldn't hear any tapping at all. I sort of checked the clearences before I adjusted them and they seemed really, really tight. I adjusted them to .008 IN and .012 EX (engine hot), and got it running. Then, I could hear a distinct tapping from what it sounds like, just one valve. I took it apart again and tried readjusting, but got the same tapping at the correct clearance specs. I readjusted a couple more times in hope I did something wrong, but I always ended up with one valve tapping.
After I changed my timing chain, before I put it back together, I adjusted the valves to .007 IN and .011 EX (engine cold). Still, the tapping remains today. Is this tapping not going to go away unless the valves are adjusted back to how tight they were before? (I don't know the exact specs they were at, but they were tight....I thought they would be loose after all those miles)
Should I take a look at the adjusting screws? Could this be causing it? I know there is an alignment issue with the rockers that can come up with the #2 and #3 (
http://www.wheelingadventures.com/Tech/Fixs.htm), but I took a good look and it seems the spacers are already oversized and not worn.
I was bored and messing around with my camera...I recorded the engine tick if you want to hear:
http://www.members.aol.com/jamy4us/truck/yota/tick.wav
Any input would be great. I guess this isn't that big of a problem, I would kind of just want to know why only one valve would be tapping when its at the same specs as every other valve.
Thanks
