22re - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 10:33 PM   #1 (permalink)
View magoo_16_99's Photo Gallery
Question 22re
I am trying to find the throttle position sensor on my 85 4runner
magoo_16_99 is offline
Old 01-22-2005, 10:38 PM   #2 (permalink)
Official TN Memburr
D'mon's Avatar
View D'mon's Photo Gallery
There is a sort of roundish black housing on the right side of the intake just after the rubber elbow screwed on to the aluminum housing. It has a plug pointing toward the front of the truck. It has two Philips screws holding it on, one on top and one underneath. Loosening these two screws and twisting the TPS is how you adjust the TPS setting, taking resistance readings from the socket.
Hope this helps.
D'mon
Heaven doesn't want me and Hell is afraid that I'll take over!
D'mon is offline
Old 01-23-2005, 01:14 AM   #3 (permalink)
View 87_SR5's Photo Gallery
Here is a site that will help you find it and adjust it:
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
If you need to adjust it (or change it out), its a lot easier to remove the entire throttle body. And while you have the throttle body off you can give it a good cleaning. I just fixed my TPS (it was out of adjustment). I tried doing it on the engine, but it was hard in such a tight area, so I took the throttle body w/ TPS off....it was a lot easier with the entire assembly sitting on the bench.
Hope this helps
87_SR5 is offline
Old 01-23-2005, 07:38 AM   #4 (permalink)
thanks that really helped i have good power until i get on the throttle then the check engine light comes on and it kills my power
Old 01-23-2005, 08:20 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
sounds like tps
fredk is offline
