"OEM" Locker:
Advantages - almost unstoppable, almost a go anywhere, no clutch plate to wear out.
Disadvantages - can only be used in 4lo and 1st gear as stated earlier, you still have an open diff in 2wd and 4hi.
LSD:
Advantages - automatic, perfect for everyday driving in all weather conditions, good for gravel and moderate logging roads.
Disadvantages - average life is 40k, helpless if one of the rear is off the ground(in 2wd), helpless in angle climbs(in 2wd & 4wd).
Did I miss anything else.
IMO, it's always better to have a locker than a lsd. But in this case toyota wanted it to be idiot proof so they made it work only in 4lo which the average joe rarely ever use. I like to have the option of engaging it at will or in my case automatic. It's totally up to you. You got along fine with open diff, a lsd would improve your go motion, a locker will get you into trouble cuz you went farther then you should, hehe, you'd be surprise.
00 Tundra
with a few mods
