Get you a couple cans/bottles of SeaFoam and start your engine up and let idle. Find you a piece of rubber hose the same size as the PVC valve hose, then disconnect PVC valve hose at plenium and slip the rubber hose over the metal tube on the plenium and slowly let it suck in about a half of the can/bottle of SeaFoam then shut engine down and let it sit for awhile. Hook PVC valve back up add rest of the Seafom to the fuel tank and fire it up again and go for a little test run were you can wind up a few RPMS and see if that don't help. It also wouldn't hurt to pull the throttle body off and with sensor safe injector cleaner or protect the TPS from it, use a toothbrush and injector cleaner to clean the throttle body, spraying the cleaner through every vacuum port and the by-pass idle vent hole!! You can plug the coolant hose with a bolt and not have to drain coolant!!
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Reason: Add to
