Originally Posted by xrs22
I think that may be the problem w/ mine. My CEL is coming on and i have a feeling that i used a little much oil on the filter. How can this be fixed, a new MAF sensor?
You can, but you can clean it yourself. If you know where it is you can un bolt it, buy some electrical contact cleaner (make sure it is safe for plastics as well) from Radio Shack or any home supply store and spray the MAF librally.
DO NOT AND I REPEAT DO NOT use a Q-Tip or anything else to clean off the wire sensors in the MAF. Just spray it down and let it dry and slap it back on. To reset your CEL, unplug the
LITTLE 15amp EFI fuse (not the larger square one) in the fuse box for a few minutes and you should be good as gold.
