22r and 22re - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2005, 10:41 PM   #1 (permalink)
View madtodaimax's Photo Gallery
22r and 22re
Whats the difference between a 22r and a 22re? I have read a few posts and it seems the celica has the same motor? will the same mods work>
madtodaimax is offline
Old 02-02-2005, 01:35 AM   #2 (permalink)
View 87_SR5's Photo Gallery
The 22R runs a carburetor, while the 22RE has electronic fuel injection.
87_SR5 is offline
Old 02-02-2005, 07:58 PM   #3 (permalink)
View Toydude's Photo Gallery
Which has more stock power? Torque? Which has more capability for high hp and tq #'s, and how high can those #'s go (estimate)?
Toydude is offline
Old 02-03-2005, 12:21 AM   #4 (permalink)
View ttownjoeshow's Photo Gallery
seems to me ( i only know '86) 22R and R-E are about 105 bhp and the 22R-TE is about 150 bhp w/ 6 psi. might b ET but its a EFI with turbo they are the shyit in the mud
i've been told that you could get 400 hp outta the turbo jobie
ttownjoeshow is offline
Old 02-07-2005, 08:39 PM   #5 (permalink)
View surplusteve98's Photo Gallery
the 22r & 22re are the same block & head the re is EFI and makes about 5 hp more in stock form. as far as what kinda hp you can make depends on how much $ you want to spend and how long you want it to last. you can get about 140hp with a cam, header, carb & intake upgrade and still have a verry reliable engine with stock internals. you can get around 200hp+ with some big pistons,compression, porting sidedraft carbs and some ARP hardware to hold it all togather. I have seen some 350-400hp turbo engines but the head and block are the only oem parts left and probably $8k later.
surplusteve98 is offline
Old 02-08-2005, 07:11 AM   #6 (permalink)
View Sidney's Photo Gallery
These sites below explain it all:
22R Series tech data sites:
http://www.babcox.com/editorial/ar/ar119838.htm
http://www.babcox.com/editorial/ar/ar400108.htm
http://www.toyotaperformance.com/4_cyl_tech.htm
http://www.off-road.com/toyota/tech/...toy_motor.html
http://www.4x4wire.com/toyota/faq/parts/
http://www.geocities.com/MotorCity/P...ct/Engine.html
http://www.toyotagtturbo.com/engines2.html
http://www.engnbldr.com/ToyotaHotlicks.htm
http://www.bitwalla.com/cruisers/info/engines.html
http://www.off-road.com/tlc/faq/engine.html
http://www.jnc.farpost.com/toytech.html
http://www.buschtaxi.net/de/01info/motoren.html
http://www.landcruiser.hu/motorok.html
Sidney
Repairs tv's,vcr's,home/car audio out of my home
E-mail:sidneybek@yahoo.com
Dartmouth,Nova Scotia
Canada
1985 Toyota 4-Runner,22R-E,W56,RN60LV-MSEK,rusted rear step/towing chrome bumper with 243 000 KM
Sidney is offline
Old 02-08-2005, 10:20 AM   #7 (permalink)
Thanks for the help guys. I was just wondering which engine (22r(e)) would make more hp easier and more cost efficient. BTW, is there a turbo or s/c out for the 22r and re? Because that would be a good power adder. I want about 200+ horses, not lookin to race, just want some grunt. Thanks.
Toydude is offline
Old 02-08-2005, 11:05 AM   #8 (permalink)
i hear ya! i have the 22R-TE ('84-'88) it has the turbo and fuel injection. The engine is damn near identical (to the 22R-E)but the pistons are alittle bit smaller (they heat up more) and the head has bigger valves. There is a web page dedicated to this engine that i have found
http://www.well.com/user/mosk/welcome.htm it is mainly about doin the engine up but you might want to check it out. in the stock form they only give you an extra 30hp but you can really feel it when she winds up!!
3 '86 Toy P/U 4X4... 22R-TE auto stock, 22R-E manual 4" susp 3" body &35's 5:29gears, and a 22RE 4Runner, daily driver.
Old 02-13-2005, 02:51 PM   #9 (permalink)
View sefus's Photo Gallery
actually the rte block has more oil passenges to help with cooling and lube. its hard to say about whats better the r or re. the re is more efficient but i have a fully built re and it dynoed like crap. ive heard that bigger power (less economy) can be had with the carbs. so its all about what you're going to use it for.
86 Toyota 4runner, 22re, 5spd: .02 over, head shaved for 9.5:1, full port and polish, 48/40 valves, dual valve springs, cam, header & exhaust, Supra AFM, SHO Taurus electric fan, removed AC, MSD 6a and coil, and a bunch of other little stuff
sefus is offline
Old 02-14-2005, 09:52 PM   #10 (permalink)
View Tafnar's Photo Gallery
The turbo block and 85-95 22R and 22RE are laser blocks. The only diff between the turbo block and r/re block is there is a oil return hole for the turbo.
And running a 22rte you can push 450-500 though you run into fuel issues because the stock ecu goes into over boost around 12-14psi and shuts the fuel off to the motor. You can by pass that by just dumping the ecu and mass airflow sensor and running a standalone or by running a alochol injection system so when you reach your 12psi the fuel shuts off all together and run basically alochol.
Tafnar is offline
Old 04-29-2006, 03:11 PM   #11 (permalink)
View charrliy525's Photo Gallery
hey man how do you run standalone-just unplug both and thats it? ive been tryen to get this abortion of a yota to start n run with no luck-was a 87 turbo but now has a 22R motor and 22R ecu n they put the efi and disty from the 24L turbo on it and she only ran 1 day since i had her and you couldnt hit the peddal more than an inch top`s-and it just bogged like u threw a bucket of air in her and no GAS-it also looks like that blue box-drivers side whitch i beleive is for the turbo is still hooked up but the turbo i guess is long gone when they put the 22R in her and not the origannal 24L(22re-t)-lol--let me know how you run standalone-im starten to think thats the problem-what you said--thanx in advance-email in deathrider_2002_33511@yahoo.com
charrliy525 is offline
