starter relay on 87 22RE 2wd pickup ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2005, 12:41 PM   #1 (permalink)
View fast68's Photo Gallery
hi, is there a starter relay on an 87 22re 2wd pickup (with auto trans) ?
this truck some mornings has a delay when you go to crank over the engine, sometimes when you turn key and hold it all way to start it it will do nothing but click once. and then a couple seconds later will crank over and start up, cranks and starts up fine otherwise
if there is a relay then where is it located ?
thanks for anything!
many 1987 toy truck parts, lots of parts inside and out, also have many '88 pickup parts still.. try me! pm or email me, also fastr68 on yahoo messenger anytime 24/7 signed in on there.
fast68 is offline
Old 02-04-2005, 12:59 PM   #2 (permalink)
View ttownjoeshow's Photo Gallery
hey, yea my '86 did that too (kindda forget how i fixed it) but my relay was behind the speeker cover on the passenger side (dash). its tough to get at!
ttownjoeshow is offline
Old 02-04-2005, 01:05 PM   #3 (permalink)
neat, yeah my covers are removed i see relays out in open in my cab, well at least the tranny converter lockup one anyways, hmm..
its almost like the ignition switch is not connecting circuit to relay or something, maybe its gummed up inside ?
if you remember how you fixed this then lemme know asap fastrrandy on yahoo messenger or fastr68@yahoo.com
thanks
fast68 is offline
Old 02-04-2005, 01:21 PM   #4 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
Before you spend $ on expensive parts, Check out the starter links that Sidney posted in Trucks section.
CraigW is offline
Old 02-04-2005, 01:45 PM   #5 (permalink)
i wont spend on it anyways, ill junk it before that, i cantg afford parts with being out of work
its on its last leg or two anyways, but does run and drive, so..
where links ? top of page or ?
thanks
fast68 is offline
Old 02-04-2005, 02:01 PM   #6 (permalink)
ok found links, now i know what needs done, cool
thanks
fast68 is offline
Old 02-04-2005, 04:33 PM   #7 (permalink)
NY born, Texas raised
texas12's Avatar
View texas12's Photo Gallery
Hey Fast68, i think the starter relay that ttownjoeshow was referring to is called the Circiut Opening Relay.
You mentioned a tranny converter lockup relay? Where is that located?
'86 4runner, 22RE, auto, 4" ProComp lift, 33x12.5 BFG All-Terrains on 15" A/R rims, clear lens front & rear, 260,000+ miles. Wanting 4.88 gears and soft-top.
'88 4runner, V6, 5spd, sunroof, power everything, 185,000+ miles.
texas12 is offline
Old 02-04-2005, 05:38 PM   #8 (permalink)
the lockup rel;ay is driver side kick panel, behind it, blue relay
i notic when truck is cold on frozen days it will not go into final gear and lockup for quite a while, it delays alot, but on warmer days its fine
truck is just plain worn out, everything barely works, but it still runs drives,
brakes barely mamking it, exhaust is trash, the slow trans lockup, starter needing solenoid contacts, one of the u joints went out it was toasted sloppy fried, and trans rear output seal blew one day,
the brakes scare me, the rear adjusters keep freezing causing rear shoes to not come out and makes pedal go lower and lower over time, and the front hoses and all the lines on the frame look horrible, the rotors are badly worn on inside face
and the idler arm is sloppy worn loose
im just gonna run it til it dies
runs good though, i have a feeling the chassis will go first,
the engine might survive if the chain guides and chain dont go, its getting pretty noisy.,
its in about the same shape as an old beater 70s chevy truck is in at 127k miles
maybe worse,.
i may not even get to the starter solenoid fix,
oh and the fuel guage doesnt work, the sender unit is dead
ive got a pic or two somewhere of the truck i could scan hehe
thanks
fast68 is offline
Old 02-04-2005, 07:51 PM   #9 (permalink)
A friend of mine just cleaned up the contacts and the plunger on my 91 Prizm starter and that solved it for me. No parts needed.
The control on some trannies is different until engine at certain temp.
CraigW is offline
Old 02-04-2005, 09:12 PM   #10 (permalink)
N/A bites
Tercel GTS's Avatar
http://www.toyotanation.com/forum/t17918.html
雄のハヤブサ
Tercel GTS is offline
Old 02-05-2005, 12:46 PM   #11 (permalink)
texas12's Avatar
I do not see that relay for a tranny lockup and have never heard of it either. Below the fuse box I have 3 relays (flasher, EFI, and i forget what else). They are all labeled and none say anything about a tranny lockup.
texas12 is offline
