88 4x4 down
Having a problem after having a valve job done, on 22re engine, after putting it back together it will start up but only run for about 5 sec. like it would if you pulled the breather hose off. I've checked and rechecked everything I can think of. I set the valves set the timeing and rechecked all vaccum hoses, I even pulled intake back off and made sure i had the right gasket on it and the injectors holes were opened. just can't get anything to work, need help on this one please . and i'am getting plenty of fuel to the cold starting. thanks
