Originally Posted by JVS
Can anyone help me with a ignition timing question. I replaced the head on an 86 toy 4x4 turbo with rebuilt head (Head gasket went bad and cracked head due to water). Put the crank at 0 degrees TDC and marked cam and chain when removing head. After new head was installed made sure it was at 0 degrees TDC and put in distrubtor so it was pointing to #1 wire. Timed truck to 5 degress BTDC and truck ran but had no power. Found that when I advanced the timing say to 12 degress BTDC it was much better. Then moved to say about 20 degrees and truck seemed to run pretty much normal. Does anyone know what might have happened?
When you adjusted the timing at first (to 5 degrees BTDC), did you short circuit the check connector plug located under the hood? By short circuiting two certain ports on the plug, this disables the electronic advance (controlled by the computer). Then you set you timing to 5 degrees BTDC and then take out the wire you were shorting it with. This will turn the advance back on and you should be good to go.
At idle, the truck should run at 12 degrees BTDC (I think)....this is with the electronic advance enabled. Then when you disable the electronic advance, it will drop the timing to 5 degrees
I think this may be your problem....
Hope this helps...
