I am really puzzled with this problem...
Last week I was driving to school, and my route only has one right turn where I don't have to stop. So, approaching the corner, downshifted to 2nd, and then took the corner, powering though it (I think I was late that day
). Right in the middle of the corner, the truck choked and sputtered, like it was about to die....but then smoothed right back out after I exited the corner.
Now I thought that was weird, so on the way home I did it again to see if it would happen (right corner) and it did do it again. One time it happened, it sounded like it back fired a little, if that has anything to do with it....
The funny thing is that I tried turning left the same way (powering through the corner) and I was not able to get it to happen. I don't know if the difference between turning left and right matters but I thought it was weird.
I thought it might have to do with the engine maybe not being at full operating temp, but I was able to do it with normal operating temps.
I thought maybe it was something with the gas sloshing around in the tank, but I had well over half a tank when it first happened.....
I just got done with replacing some parts also...timing chain set, 02 sensor, cap/rotor, plugs/wires, coil, got my TPS adjusted and working.....is there anything else that I should think about replacing? I know I haven't done the fuel filter in a while.....
Any ideas??? I am going to go out and experiment some more and see if I can determine exactly when it happens and if I can get to do it everytime..etc...
'87 SR5 4x4 22-RE 170,000 miles
Other than this problem, the engine runs great...
