Power Steering Fluid? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-12-2005, 07:50 PM   #1 (permalink)
View DesertDave57's Photo Gallery
Question Power Steering Fluid?
I have an 87 Toyota 4Runner 5 speed standard with the 22R-E engine in it. The power steering is starting to sound a little rough, so I consulted the owners manual before adding fluid. It says to use Dexron or Dexron II Transmission Fluid. Is this correct? Just wanted to be sure. Thanks for your help.
DesertDave57 is offline
Old 02-13-2005, 05:40 PM   #2 (permalink)
View Smoke's Photo Gallery
Yes that is correct!! Do not use power steering fluid unless you like to change out power sterring pumps!!
94 Toyota PK Ex-Cab 3.0 4X4 Auto
Smoke is offline
Old 02-13-2005, 06:29 PM   #3 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000164
View humanoid's Photo Gallery
Yeah, that's correct. Your manual is your car's Bible!
This is my sig.
humanoid is offline
Old 02-13-2005, 09:47 PM   #4 (permalink)
Thanks for the info! Better safe than sorry. Have a good one!
Old 02-14-2005, 06:27 PM   #5 (permalink)
Stop buying garbage
peterng's Avatar
View peterng's Photo Gallery
Canada Uh ?
unreal ... I just got done a mighty proud job on the tchain kit, and I just rolled the truck out of the garage yesterday ... with power steering fluid in the power steering pump.
So I'm going to casually saunter out to the garage and consult my bible to see if my 89 22re is going to get flushed momentarily or not. What a bugger, so the PSP fluid has detergents that will eat plastic or something I assume eh?
Pete
peterng is offline
Old 02-14-2005, 08:35 PM   #6 (permalink)
The ATF has better additive that keep the seal soft and pliable!!
Smoke is offline
Old 02-15-2005, 09:14 PM   #7 (permalink)
Stop buying garbage
peterng's Avatar
alrighty, I've flusdhed it a couple of time with atf and got the right stuff in it now, have to keep an eye on er and see if 24hrs exposure to the PSF wrecks it or not.
Thanks, glad spotted this post
Pete
peterng is offline
Old 02-15-2005, 11:24 PM   #8 (permalink)
Uses more oil than gas.
79 Yoda's Avatar
View 79 Yoda's Photo Gallery
hmmmm...When I picked up my truck it had psf in the resivour (sp?) and haven't had a problem yet...I think I'm going to flush it. I don't have a manual and one know how to flush it on a 79 toyota hi-lux 20R?
79 Yoda is offline
Old 02-16-2005, 07:31 AM   #9 (permalink)
Disconnect the return line at the reservoir, plug reservoir return inlet tube, route return line to a container to catch old fluid and start the flush process, adding ATF till the fluid is all pretty and red!! Simple as buttering toast!!
Smoke is offline
Old 03-27-2005, 12:54 AM   #10 (permalink)
View Skunkworks77's Photo Gallery
How come when they come out of the factory, it is using power steering fluid in the system? Even the reservoir has the clear fluid. It does not look like ATF.
2001 Lexus ES 300 top of the line fully loaded.
1994 Toyota Camry with cleared lens and S2000 HID projector retrofit.
Skunkworks77 is offline
