Power to the Fog Lamps? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-13-2005, 08:16 PM   #1 (permalink)
View pkarie's Photo Gallery
Unhappy Power to the Fog Lamps?
2003 6 cyl 4dr Prerunner and it has fog lights but no controls or power. Never really noticed until I ran into heavy fog in the
N. Arizona Mountains. I suspect all that is needed is for fuses to be installed somewhere in the fuse box, but have no idea and this was straight from the factory. No indication where the fuses go. Logic says the 10 amp slots near the other light fuses. Anyone run into the same issue with their Prerunner?
pkarie is offline
Old 02-13-2005, 08:22 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
back to the factory you go :P
or the dealer.
terrastrife is offline
Old 02-13-2005, 08:28 PM   #3 (permalink)
THIS SPACE FOR RENT
humanoid's Avatar
Gameroom cash: $1000164
View humanoid's Photo Gallery
Don't think the fog lights came standard on the Taco, but I could be wrong. Any pics of what you might be talking about?
This is my sig.
humanoid is offline
Old 02-13-2005, 10:02 PM   #4 (permalink)
Give me somethin to break
View Greasygreg's Photo Gallery
I think I am agreeing with humanoid on this one.Think you have mistaken the blinkers for foglamps.Try this,...turn on hazard flasher,and go look and see what blinks
05' Tundra Doublecab 4x4.Gold & been Rolled,various other projects follow the leader,he's in a beater!
Greasygreg is offline
Old 02-14-2005, 03:02 PM   #5 (permalink)
nofear4189's Avatar
View nofear4189's Photo Gallery
if someone did put fog lights on, check to see where the wires that come out of the lights go to. They should go to a switch in the cab or somewhere. Sometimes the lights are wired to a cig. lighter or 12V outlet. Check where the wires run to and get their power from.
-Adam-
1992 Toyota pickup 4x4. 3" body lift, Skyjacker Nitro 8000's, ICW alloy rims, 31X10.50" tires, K&N drop-in w/ airbox Mod. Sony Xplod head unit, MTX & kicker front speakers, BAJA and APC lights up front, Accel SS coil
nofear4189 is offline
Old 02-15-2005, 11:18 AM   #6 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
yeah if you got some aftermarket fog lights simply follow the wires. IF they come stock then you may wanna go back to the factory or dealer in which you got it from.
If they are aftermarket, PM me and i will put up a wiring diagram, they are fairly simple.
vsixcamry is offline
