differential switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-15-2005, 07:07 AM   #1 (permalink)
View Hallmoniter_11's Photo Gallery
differential switch
Hey guys. I just joined yesterday and I have a couple of questions. First of all, I wsa wondering if it is possible to take the rear differential lock off of a 1998 pickup I have and put it on my 1994. And if this is possible, how would i go about doing it?
Hallmoniter_11 is offline
Old 02-15-2005, 01:35 PM   #2 (permalink)
View greasyjeep's Photo Gallery
1st of all - anything is possible
2nd - a couple of questions
are you swapping the entire rear or just the locker
if just the locker you will need to make sure you have the same rear
you will also want to make sure your gear ratios are the same, if not you need to change one or both, whatever, they just have to match
if you are swapping the entire rear, make sure the spring perches are the same width so your springs will lay on them well.
I know some folks say a 1/2" in either direction is ok, i just don;t see the point
if they don't you need to buy some spring perches and have them installed or weld them on yourself (not familiar how handy you are)
also want to make sure your shock mounts are in the right spot.
good luck
more details in your question helps
greasyjeep is offline
