Yeah, you need to make sure its tdc compression for starters. Either pull the cam cover and turn the engine over by hand until the timing mark lines up and make sure the cam lobes are nowhere near either intake nor exhaust rockers on #1, or, you can pull #1 plug and turn the engine over by hand until you feel air forcing out past your finger, then line up to the timing mark. Then check the dist.
If that's good, and compression is good, check your firing order on the plug wires.
The guy at the shop is thinking about hydraulic lifters, which you don't have, so never mind that.
Bob Raby
Santa Cruz, CA
'88 Alltrac (broken) FOR SALE
'87 4x4 Toy Truck SOLD
'90 4Runner (3.4 swap, CA certified legal with K&N intake, modified thermal coated headers, 2.5" exhaust, and almost as fast as a stock 3rd gen  ) SOLD
